2000 XJ8 Cylinder 6 Misfire & a Broken Clock
I have a 00 XJ8. Restricted performance came on, so we started the cheap route and replaced the spark plugs. Kept happening. So we replaced coil 6 and 2 (we switched them to see if the same code would come on) which it did, so we can rule out a bad coil. What else could be causing this because trying to figure it out is expensive. Also, cloxk works but is really slow. Like it will lag behind.
Don B (09-07-2016)
Received 13,344 Likes
