2000 XJ8 - excessive oil consumption
Going through a quart every tank. No drips or puddles. Every now and again (once a week or two) a bit of blue smoke on start-up but not regularly by any mean.
I see a bit of oil on the valve covers but nowhere else. Also not sure if relevant but occasionally the car runs a little rough at idle. However at driving rpm normal power and smooth.
Wondering if all the symptoms (oil consumption, rough idle, occasional smoke on start) are likely related or? The engine was replaced by previous owner by a good Jag mechanic and not all that many miles on it - maybe 50K
Could it be something relatively simply like valve cover gaskets? Or am I looking into a deep dark hole? Suggestions for fixes or least expensive way to diagnose would be welcome.
Steve
San Diego, Ca
Steve
San Diego, Ca
I have experienced the too full situation. If I fill to top mark it is down a quart in less than a thousand miles. It then just stays there. There has been some discussion about Jaguar increasing the capacity principally by changing the dip stick marks.
Have you pulled a plug to see if it is oily? Try leaving it a qt low and see what happens. Changing the valve cover gaskets is very easy and they are less than $40 if you buy the FelPro ones for the Lincoln LS 3.9L '02.
It's not a "too full" problem. It will drop down off the dipstick if not refilled.
I've noted in searching the forum some folks recommend some sort of Engine Restore additive or using heavier oil - currently always have used 5-30 and change the oil every 4K. Thoughts or suggestion on the Restore or heavier oil suggestions?
If someone would be so kind as to walk me through, step by step, the things I should check or do it would be a big help. I'm not a gear head by any means but I can follow directions, and in San Diego Jag service is ridiculously pricey - so learning of anything I can do on my own (with the guidance of you vets!) would really be a help.
Thanks in advance.
Thanks in advance.
Received 2,192 Likes
Steve
San Diego, Ca
Steve
San Diego, Ca
YES I ALMOST ALWAYS AM THE 1 TO RECOMMEND HEAVIER OIL AND OR ENGINE RESTORE. i HAVE HAD MANY ISSUES WITH JAGUARS AND OTHER THAT NEEDED A HEAVIER OIL FOR VVT(VARIABLE VALVE TIMING FAULTS). OIL CONSUMPTION ETC. THERE ARE TIMES IN A RINGS LIFE THAT IT CANNOT EFFECTIVLY CONTROL THINNER OIL AND THIS DOESNT MEEN ANYTHING IS REALLY WRONG EITHER. SWITCH TO ADDING 20-50W NEXT TIME AND SEE IF IT IMPROVES USEAGE. IF IT DOES JUST CHANGE TO 20-50W NEXT OIL CHANGE. ENGINE RESTORE WORKS WONDERS TOO BUT YOU NEED ABOUT A BOTTLE AND A HALF OF V8 ENGINE RESTORE FOR JAGUARS OIL CAPACITY.
I ALWAYS BELIEVE IN TRYING CHEAP EFFECTIVE FIXES FIRST. UNLESS YOUR ONE OF THE PEOPLE THAT JUST HAS ALOT OF DICRESSIONARY INCOME(I KNOW YOU DONT SINCE YOURE LOOKING FOR HEADLIGHT TRIM)
Guest
Posts: n/a
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hi
I have an S Type and an XJR.
When I bought my S Type it was using a lot of oil. Not as much as you but 2 litres in 1000 miles.
I changed the oil for a full synthetic and after a couple of thousand miles the consumption has dropped to almost nothing.
I used to work for Rolls Royce (mechanic) and in the dealership people were always coming in complaining of high oil consumption after being serviced by 'specialists' or just Jo at the garage. We swapped them on to Castrol full synthetic and the problems went away.
Before anyone starts shouting about glazing the bores etc, that is just urban myth, synthetics are the way to go.
Regards
Peter
Regards
Peter
Hi
Regards
Peter
Regards
Peter
What viscosity did you use?
hi
i have an s type and an xjr.
When i bought my s type it was using a lot of oil. Not as much as you but 2 litres in 1000 miles.
I used to work for rolls royce (mechanic) and in the dealership people were always coming in complaining of high oil consumption after being serviced by 'specialists' or just jo at the garage. We swapped them on to castrol full synthetic and the problems went away.
Regards
peter
Regards
peter
Thats only an issue with new rings not seating and incorrect crosshatch/stones used for the ring set used. Talking to him privately the engine was not rebuild but repaired by the previous owner at a shop that gouged that guy. The repair was for a snapped chain and bent valves . I already explained to him that that could be a non issue. Or could have hit the piston top hard enough to push metal over tightly to the cylinder walls and or tightened a ring land which leaves to ring clearance for it to move and will destroy itself. But thats all conjecture and if's. Only thinking out loud. Ive had valves hit pistons hard enough with a chain break on the v8's to break the piston and crack a cylinder wall
Got a 99 XJ8 with over 168k...using Castrol high mileage 10W-40...added only one can of engine restore at the last change...no change in oil use pattern. Next go round will be changing over to a heavier synthetic and add a can and a half as suggested by "Brutal"....Did I mention that I would be doing my own change next time as the local tire, tune & lube got me for about $86?
As a side note, Jaguar changed the recommended engine oil to Shell Helix HX7 5W-30 some time last year, it has synthetic properties. Maybe look at a heavier oil in that range.
So, can anyone claim ACTUAlL improvement in oil consumption from somehting bad, like 1 qt per 1000 miles to something reasonable, like 1 qt / 2500 miles, after either changing oil or running an additive. Really?
I BELIEVE I saw an improvement in my '98 XJR (with 200,000 miles, then) after I went to symthetic 10 w 40 Mobil1. But it was modest, like a qt/ 3000 miles to a qt. / 5000 miles. The engine has 240,000 miles now, and runs good.
