2000 XJ8 Intermittent Fuel Delivery Problem?
Old 06-17-2012, 08:20 AM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
None of the techs on JF like the aftermarket metal impeller waterpumps.
Old 06-18-2012, 08:23 AM
Past_Miner's Avatar
I have heard this multiple times. It's interesting, I work with heavy industrial machinery for a living, including every style of pump ever made, and the material of the impeller should make absolutely no difference as long as the impeller is shaped the same. I would have to assume that the metal ones are cut different and that leads to the cavitation problem. Too bad, all things being equal metal impellers are usually a better choice than plastics in clear liquid service just because of their longevity. I am not having any cooling problems so I have decided to leave the current pump in place anyway. I guess its a non-issue for me.
As an update on the starting problem: I have not had another problem since I cleaned the MAF and changed the plugs. I believe I just flooded the engine and had to work my way out of that situation. I have started to clean the MAF at every oil change and that seems to be keeping this problem away.
Old 07-09-2012, 01:16 AM
jbumknight's Avatar
remove all of the ignition coils and take a look in the holes with a flashlight. do you see any oil? if you do than its time to replace valve cover gasket and seals.
toronadomike
08-07-2022 03:41 PM
Sprayall
05-30-2021 08:13 AM
alpecsa
09-07-2015 11:55 AM
Sprayall
09-03-2015 07:49 PM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: 2000 XJ8 Intermittent Fuel Delivery Problem?
