2000 XJ8 motor swap
It certainly will not be a direct swap. Easiest description is that you can reuse the short block. It would be much easier to find an AJ27 engine. That is the '99 - '02 XK8/XJ8. The '03 XJ8 4.0L will also work but the model year varies with your location.
As test point says..............
The problem with the Supercharged engine block is that the pistons are 'dished' to lower the compression ratio. You will not be happy with the lower power. The SC engine also lacks the VVT so you will be swapping MANY components.
Leave the supercharged engines for the supercharged cars!!!!!!!!!!!!!!
bob gauff
bob gauff
