2000 XJ8 no start
2000 XJ8 no start
Car ran for 30 seconds then slowly lost rpm and shut off like out of fuel. Put some gas down throttle body and fires for a few seconds then shuts off.
Things I have done/checked:
Fuel pressure at the rail - 40psi
Pulled injectors rail and cranked and injectors are all firing and spraying fuel
Checked for fuel bleed off and had none, pressure held
Check spark and have spark
Checked Voltage to cam sensors- 5v
Fully charge battery
Replaced crank sensor.
Did it throw any readable codes that you can scan and point the right direction? Will it run at all if you pump or feather the throttle pedal? Long shot, but I had a broken connection to my MAF once and it died on me, and then would crank and not start. If I feathered it, I could just barely keep it running, but barely. It actually took a little while before it would throw a code, which finally put me on the path. However, in my case it was a short so when I unplugged the connector altogether, it would start and run fine, though under Restricted Performance. So it's a long shot, but just happened to be what happened to me.
Received 1,815 Likes
You only have the # 1 fuel pump on the non supercharged engine . You can swap the relay with relay X
The relay clicks 3 times in the starting sequence on - off - on . You may have been pressure sensing the first 2 click commands to prime the fuel rail only . the 3rd click back on comes from the CKPS through the ECU . Better to put your finger on it . Listen also for the pump to run during the clicks while the trunk is open .
If all your reading are valid as a testing configuration look at the transmission body connector ( push / pull connector ) as it has a history of being contaminated stalling the engine .
Both of your MAF sensors will read 0.50 volts DC at the correct idle speed on the center wires .
Since you know that you have fuel pressure and have determined that you have spark. I would pull and clean the crankshaft position sensor face and check the wires for damage. It is mounted on the right hand lower side of the flywheel housing. The CKPS is the one to tell the ECU that you are cranking and want to start.
The following 2 users liked this post by avern1:
Highhorse (06-27-2018),
Lady Penelope (06-27-2018)
Finally got time to get the car to the shop. Ended up being water in the fuel. The drain was clogged in the fuel fill area and with all the rain we have had, it filled up and went into the tank. Thanks for all the advice anyway. Hopefully I now get to enjoy the car for more then a 100 miles this time.
The following 3 users liked this post by 2000XJ8:
