2000 xj8 passenger headlight bulb replace
I haven't done this in a while but if I remember it's not too difficult. If you open the hood I think you can see the back of the headlight housing, then there is the bulb wire and bulb "socket." I think you twist the bulb "socket" 90 degrees and then pull it out. then you have the bulb in the socket, to get the bulb out of the socket, pull on it. don't touch the bulb with your fingers, the grease on hands can shorten bulb life.
good luck
good luck
rudelover2
09-11-2015 08:53 PM
Will P
08-27-2015 06:52 PM
