2000 XJ8 Transmission Fault Light
So let me start at the beginning. Restricted performance came on at one point or the other and had the code checked for the check engine light and it said "Cylinder 6 Misfire". Tried a spark plug change as a quick fix. Stayed the same. Tried changing coil 6 and coil 2 to see if it was the coil. Stayed the same. Then recently, Transmission Fault light came on and the car will go into reverse just fine but won't go into drive. In drive it is really sluggish and doesn't really accelerate. It revs up just fine. Could the transmission be crapping out as well or is it just shutting down to prevent further cylinder damage? Any ideas?
If your car is a 2000 XJ then it's an X308 (1997-2003) and unfortunately you've posted in the wrong sub-forum; you should post in XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum
This sub-forum is for the X350/X358 model which ran from 2003 to 2009.
Received 4,280 Likes
LoganR
09-07-2016 11:26 AM
new2jag2016
08-27-2016 01:02 AM
keelak
08-26-2016 07:58 PM
