2000 xj8 transmission valve body
Hi
Look at post# 11 and the other posts in XJRJeff thread "Off the road again"
https://www.jaguarforums.com/forum/x...d-again-61537/
Also this thread:
https://www.jaguarforums.com/forum/x...ssembly-54866/
ZF5HP24 Transmission Repair Manual:
https://www.jaguarforums.com/forum/x...hed-faq-54929/
Jim Lombardi
Also this thread:
Jim Lombardi
Watch when you take off the plate that holds the pressure regulating valve in. The springs in there are short but very strong. It won't hurt you. but I was worried that the pressure might damage the threads on the last turn coming out. Support it so that the screws aren't taking all the load.
It can be done by one guy, but you need a way to hold the valve body in position while you press hard to remove. or even more important, install the screws.
