2000 XJ8 Trunk Lights
Old 04-28-2016, 07:48 AM
xjay8's Avatar
Originally Posted by 1987turbo
Thank you. I'll give it a try ~ 5 fuse boxes ~ what were they thinking? in.
Welcome to the joys of Multiplex wiring systems ;o))
Old 04-28-2016, 07:51 AM
xjay8's Avatar
Jim, That is what the problem was. One of those little wires was broken. It took me awhile to figure out the trunk light only goes out when the trunk lock is engage -- no mercury switch like the old days.
You will find that the trunk lights are the same as the door puddle lights,
they are on a time sequence and will self extinguish after a period if you have your doors or trunk lid open for an extended period ;o)
Old 04-28-2016, 01:15 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
Originally Posted by ericjansen
A bit more complicated:
There is a leather surround glued on the carpet, giving it a stiffer base to click the light unit in.
My leather surround was loose as well, just re-glued it.
Just be a bit careful re-installing, better first install the carpet without the side pins, then click the light units in while having a hand behind the carpet to give some back pressure to the leather.
Yes my leather base was found loose further down the wiring. Now I have basic schematics in my mind, I can figure it out.
Thanks sir.
Old 04-28-2016, 02:48 PM
GGG is offline
Received 16,861 Likes on 12,186 Posts
Originally Posted by King Charles
Anyone have a diagram on how the trunk lights attach to the lid .....
Relevant section from the Vehicle Care Handbook:
King Charles (04-28-2016)
Old 04-28-2016, 04:41 PM
Yes these are trickier than they look lol.
Old 11-18-2016, 06:48 PM
henry crun's Avatar
After wasting time and money acquiring and replacing several failed OEM boot/trunk light micro switches, I have used a mercury switch alternative. MS's are available from any electrical component store for a fraction of the cost & are easily installed without trunk latch removal. Simply unclip the boot lid lining and splice the 2 mercury switch wires into the 2 boot light switch wires (polarity is irrelevant) and affix the mercury switch with double-sided adhesive tape in the appropriate orientation under the boot lid lining. With the car parked on level terrain, ensure that the boot lights go off just before the boot is closed. Note that because the mercury switch is gravity operated it may activate the boot lights if the car is parked in a steep nose-down attitude. If so, the security control module will prevent battery drain, but you will need to use your key to open the boot!
Bcrary3
09-12-2021 05:41 AM
mbergen
10-23-2019 10:26 PM
dsnyder586
04-04-2019 02:38 PM
martybmw
04-02-2016 04:55 AM
KarimPA
09-12-2015 08:15 AM
Quick Reply: 2000 XJ8 Trunk Lights
