2000 xjr brakes?
ORIGINAL: river
I'm trying to purchase brakes for my 2000 xjr nd all these shops online give me 2 options or "different types" of pads. Do all 2000 xjr 4.0L supercharged Jags have the same interchangeable brake pad, both front and rear?
What were the options you were given?
Also, more importantly is to make sure your calipers can slide laterally with no restriction. This will insure that the inboard and outboard pads will wear correctly and will not cause excessive heat from rubbing on one side. Heat is a rotor killer and if allowed to occur will cause hard spots on your rotor which will show up as a pulsating brake when coming to a stop
I will always be pro-ceramic padding. My mechanic just popped this on mine
http://cgi.ebay.com/ebaymotors/ws/eB...89570&rd=1
the works. super inexpensive,breaks are SWEET now, very tight with such a smooth feel.My opinion.. semi-metallics are no dice. Nasty break dust and squeals.
Yup on the expensive for the "R" or "R1" packages.
Pads, front only, for my 03 XJR/R1 (Brembo)package is $500 from the dealer, and I'll be looking at rotors next time too. 64K miles.
They can be found cheaper, but I have no links at the moment with the new computer. I lost all my research.
http://www.europartsdirect.comshows them at an attractive price. No affiliation, and not a customer.
Based on research only, this advice is worth every cent you paid for it.
KarimPA
09-12-2015 08:15 AM
