2000 XJR bypass hose
Gents,
The bypass hose on my '00 XJR was very swelled up so I cut it off and obtained a replacement. This is the 90 degree elbow hose that is on the back side of the water distribution pipe. I'm having a hell of a time getting the new one on so I'm thinking I have to remove the metal pipe in order to get more clearance. Is it just held on with the two bolts at the front of each cylinder head? If someone could post JTIS instructions, that would be swell (pun intended)
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
this is the thread that talks about removing the supercharger. you have to remove the "water disribution pipe" to get the supercharger out, so the PDF is in there
maybe this will help you
https://www.jaguarforums.com/forum/x...f-files-58889/
good luck
good luck
Thanks Sean,
I wound up releasing the water delivery pipe from the front of each cylinder head. As I did this over the weekend, I wasn't able to obtain new o-rings for the pipe connections to the heads so I got the new hose on, put the water pipe back on and crossed my fingers. So far, 50 miles and no leaks. Now to figure out what else is causing my ABS light, ASC NOT AVAILABLE and TRACTION NOT AVAILABLE messages, as I just had the ABS module rebuilt, hoping that was the silver bullet...
![Icon Gunhead](https://www.jaguarforums.com/forum/images/smilies/icon_gunhead.gif)
KarimPA
09-12-2015 08:15 AM
