2000 XJR electrical Probelms
Hi,
I have a 2000 xjr that is giving me lots of error messages (mass air flow, tps,cam positions sensor, check engine light ect..) I have these problems and the car runs like a dog along with throwing engine faults that the require me to turn the car off then on again to clear; however when i pull the battery out and charge it with a battery charger then it runs like a champ with no errors thrown and the check engine goes off. could this be a problem with the battery or the alternator? I have very little experience working on a Jaguar or trouble shooting problems.
Do you have an Autozone, Advance or similar auto parts store near you? If so they should be able to test them for you. You should also check and clean the connections of the grounding straps on your vehicle, this could also be a source of your problems. You can also check the sticky's at the beginning of this forum in the how-to section.
Received 1,794 Likes
Yes, these cars hate low, dead or dying batteries. How old is it? Have you had it tested?
Vector
![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
Michael Wittmann
03-29-2016 05:16 PM
Michael Wittmann
03-27-2016 07:45 PM
