2000 XJR Fuel Pump
2000 XJR Fuel Pump
FHey Guys! I thought i remembered reading on here about the possible compatibility of the Ford Lightning fuel pump for the XJR. Im thinking thats going to be my next mod. Does anyone have any idea on where to find a heavier flow fuel pump, and what injectors i should use? Or, any help on how to access the fuel tank? Thank you very much!
the lightning uses two pumps like our cars, the fuel pump is 100 something lph, pretty much the same size and some use the same ford connector. as long as it fits in the bracket and you can splice 4 wires any aftermarket 255lph pump should work.
best way to access the tank is taking out the rear seats, parcel shelf, speakers and then grinding a cutout flap.
Z07Brandon (02-13-2021)
Stock pumps are ~120lph ones.
EDIT: Stock 4.0 R injectors are 360cc / 34lbs @ 3bar / 43 PSI . You can go quite far with those if you eaise fuel pressure. If you use E85 - then another story.
The following 2 users liked this post by XJR-99:
xalty (02-13-2021),
I do not understand why would one want bigger flow pumps than stock on a stock fuel system. The extra flow will do nothing good as it has "nowhere to go" and will just cause much higher bypass/return flow pass the FPR which may overwhelm the FPR and cause poor running.
Modified (race) engines are another story.
if you don’t have a heaton it may be of some use to do this. adding the aj34 rail increases the fuel pressure and allows you to run the 500cc@? psi injectors
Here are photos of the parcel cutout during and after pump replacement. I actually put a large welding blanket over the top of the fuel tank and tack welded the "flap" back into position before sealing the seam. Live dangerously! If you tack weld back in place, you can cut into the speaker area for more access to the hose attachments. And here's a related thread: Fuel pump replacement options - Jaguar Forums - Jaguar Enthusiasts Forum
