2000 XJR help me open boot, key will not turn in ignition or in the boot.
motorcarman (07-08-2024)
Open the hood and on the passenger side behind the shock tower is a large diameter cable with a rubber cap over it. You can apply power on there and some form of life should appear. You may need to charge there for a while depending on how dead the battery is. Turn the steering wheel while you’re turning the key in the ignition.
With the battery being charged up , slightly move the shift selector slightly out of the park gate ( not in park switch ) and with your finger on the key barrel you may feel a key barrel solenoid click locking and unlocking the ignition key barrel
Do rock / turn the steering wheel left and right
Your right Randy, the trunk should open with the black key even if a battery wasn’t in the car. The key cylinders need to be exercised occasionally (and dry graphite lubed) but, I get it. The key fob bypasses all that mechanical work.
It’s the path of least resistance until it resists back.
I left my keys in the boot , locksmith wanted 65 quid , I drilled a hole a wiggled a rod around and it unlocked.
Assuming the key is the correct one, the lock cylinder is probably just frozen. Lubricate it and start working the key back and forth to the right (clockwise). It will eventually free up and the lock will open.
I see in your other thread that you have a battery charger on it under the hood. You said you have the ground on the shock tower bolt, which is probably not a good ground point. Do you get any lights on the car when you're connected with the charger? Headlights? Interior light? Dinging from the ignition key in the ignition? If not, then you're probably not energizing it well enough and you should look for a better contact point. I'm not sure where but I think there is a good ground point near the fuse box on the left side? Anyone else have specific points to apply power and ground to?
Rodge
07-10-2024 08:53 PM
Windycityx
11-24-2013 06:56 PM
