2000 XJR P0705 and Gearbox Fault
Hi everyone. semi-Nube here.
I am getting a P0705 code set. I observe shift indicator lights go out when occours with a gearbox message. Seems to be worse after cold soak. i'm thinking a linear switch issue? Maybe loose dirty or out od adjustment?
I guess console must come out to access?
I work on XJ8 all the time. Just not familiar with this XJR setup(trans).
I took console out. All was tight in shifter area. Removed Linear switch and disassembled it by removing three screws. Cleaned contacts and mating surfaces with contact cleaner. Slightly increased contact point tension. reinstalled and adjusted, Problem resolved.
If anyone ever needs help with this drop me a note.
Catenaccio (02-07-2014)
