2000 XJR parts manual
Does anyone know if there is a parts manual, or parts list of any kind available for a 2000 XJR? I would like to have part numbers handy when I order something from a dealer. Sometimes it's hard to explain what hose, screw, clamp, bracket, etc. that I need. I have been lucky a couple of times as there would be a vehicle like mine in the service area and I could walk back and point out the part. I have the JTIS, but it doesn't give many part numbers. Thanks, Louis
There is a Jaguar Electronic Parts Catalog download
Looks like the parts manual listed in post #3 is going to be a lot smaller than the download I have listed below. Being smaller in this case is a good thing since it has infomation specific to your XJR.
The file download has the following Jaguar models listed:
latest XJ, XF, XK then others by Vin number range XJ, X-Type, S-Type, XK8, XJS, earlier XJ models, XJ6 & XJ12 (XJ40), Series III Saloon, Daimler Limousine, and Jaguar Accessories.
If you still need to download this file then use this link to go to the download for Jaguar Electronic Parts Catalog file:
https://www.jaguarforums.com/forum/s...s-48052/page4/
Once you open the thread: go down to post#1 for instructions on how to download the file and the download file location. After you start the download, the screen gives you the download file size of 264 megs. With highspeed internet download speed about 600 kb/sec it takes about 8 minutes. I did not understand why the download file size is so large. It looks like this software takes only about 5 megs of diskspace after you install it.
Jim Lombardi
Jim Lombardi
The following 3 users liked this post by jimlombardi:
innzane
09-02-2015 10:08 AM
