2000 XJR Pinion bearing and seal
Seal here, part number JLM20326:
SNG Barratt - The Ultimate Jaguar Parts Specialist
No idea what's involved in fitting it, it may be a lot easier just to get the whole kit (which SNG Barratt have as well, part JLM20602).
Is yours leaking at all? Mine had a slow leak, and I procrastinated a bit too long before ordering the kit, and ended up blowing the whole diff
motorcarsrandy (01-29-2014)
I should have mentioned that the cause of my leak was pressure building up because of a blocked breather. You don't need to buy a new one, just give the old one a clean and it should be fine.
Of course, getting to it is another story... but you'll want to drop the subframe to do the pinion anyway, so it should be easy enough to take this out and clean it up before putting everything back together
Wow wow wow
All I can say is WOW. Reading another thread,it stated they had found pinion nut loose and resolved noise.
mine has been driving me crazy. For grins I dropped shaft and behold turned pinion nut 3/4 turn befor resistance felt. Snugged down and so far all I hear are the sipes of my new tires.
I will up date after sustained hot run.
Pinion howl be gone so far.
aholbro1
08-05-2021 05:02 AM
