2000 XJR restricted performance?
Hi,
I have a 2000 XJR with 71k miles on it.. recently it's been acting a bit funny.
"Restricted performance" warning with yellow light comes on if I go over 75, and goes back off if I drop under 70. CEL stays on after RP warning goes away. I also had the car go into failsafe mode once, but it also went away after I shut the car off overnight and started it the next morning.
Before this started happening, it started to get sluggish/seems to be choked under acceleration unless I floor it.. doesn't happen when it's cold out before the engine has warmed up.. only if it's warm out (even when the engine is cold) or the engine is warm and it's cold out.
What could this be? MAF sensor problem?
Cool, I'll give that a shot. Thanks!
The local precision tune said there were no diagnostic codes when they tried to get info from the computer, just a P1000 which they said was generic so I'm not sure what the restricted performance is about..
the car also seems to have some sort of rev limiter at 3000 rpm when it's not in gear.. I wonder if I actually have 2 problems, the MAF and something else
ORIGINAL: Donzi
It will!
It will!
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
restricted performance message doesn't seem to be coming on either.. so I'll wait and see a bit, but I believe that it may be resolved. Cant believe a $200 part and 5 minutes made such a difference.
thanks for your help guys
well, now it's going into failsafe mode.. done it twice tonight. turn off, start it again and it's fine.. check engine light isn't even on after restarting
I wonder if fixing the MAF exposed another problem. sigh.
I recently had new brakes/rotors installed and sparkplugs changed also.. would either of these affect any systems that would cause a failsafe? it seems to happen after quick acceleration followed by coasting for 10-15 seconds.. first time it happened the engine actually stalled completely.. I wonder if I got bad gas or if there's a fuel filter/pump problem. I really need a code reader [:@]
2000, bad, displays, fix, gasrestricted, jaguar, light, mide, mode, performance, performance2000xj8, restricted, warning, xj8, xjr
