2000 XJR slow to warm up
Gents,
Now that the weather is cooling off for autumn here in the Midwest, I've noticed that my XJR takes a rather long while for the coolant temp gauge to get up to the normal mark. My heat seems to be fine, although it hasn't been cold enough to need it full blast yet. About the only time the gauge will get to normal is after I've shut it off and let it "heat soak" for a while, then it's back to normal....until I've gotten back on the highway where the gauge will fall from normal about 4-5mm below that. Think I have a failing stat?
Thanks all!
Thanks all!
