2000 XJR Will start on first try, then no crank w/deathscroll
Old 05-17-2024, 10:17 AM
Eric Cahill's Avatar
@motorcarman So looking at the forum for CAN bus i need a more advanced scanner to do this. Or will a multi meter work. Also reading the faults showing on the message center are all CAN bus related. Is there a way to trick the system. Also I have another XJR for parts my first one, same year, color and everything. It is just rusty in all the places they rust but it is a good running unit. Could I swap any parts over. Things I have tried brake switch, swapped J gate. thank you
Old 05-17-2024, 10:50 AM
Received 8,067 Likes on 4,867 Posts
My question is still not answered. (Has Service Action S484 been performed?)
I posted the Service Action TSB.
Don B (05-17-2024)
Old 05-17-2024, 10:53 AM
Another development while using my scanner it wont connect when the P isnt illuminated. But all of a sudden it came to life, it is looking like leaving the key in the on ACC position it will finalley come to life. I am getting relieved here this might be the problem and finally have something to go off here.
Old 05-17-2024, 10:55 AM
@motorcarman No I have not performed that yet. I just got time to dive into this, I havent forgot about your post last winter I will look into this. Thank you, you have been a great help.
Old 05-17-2024, 11:17 AM
@motorcarman I will try to tackle the cluster here soon. Have some time now, not sure how long this will take. But that pretty much looks like step 1 LOL. Thank you
Old 05-17-2024, 12:15 PM
Old 05-17-2024, 01:02 PM
I did this service, solder was touching other contacts. It did not fix the issue nocrank
  #28
Old 05-17-2024, 05:32 PM
The INSTPK does NOT need configuring so I would substitute a 'known-good' part and try to start the engine.
The mileage will follow the INSTPK so be aware of this.
Old 05-17-2024, 07:44 PM
I have a good parts car, so you think changing the cluster may solve the issue. i can try this.
  #30
Old 05-17-2024, 07:46 PM
xalty's Avatar
Received 1,060 Likes on 851 Posts
a bad cluster will not cause a no crank condition
im pretty sure the dual linear shares a ground withbthe GSIM (jgate illumination module) and if that goes out you cut off the entire powertrain can network and get the the death scroll. use a test light and figure out what’s going on
  #31
Old 05-17-2024, 08:46 PM
Addicted2boost's Avatar
Received 1,029 Likes on 809 Posts
I know for a fact on our 98’ XJR (AJ26S) that the car will start, run and drive just fine *without* the IP in the car. When the car was with the previous owner, he kept having issues with all the back lighting in the IP going out. We had the IP out of the car and he absolutely had to drive the car so we let him take the car while the IP was still at our shop. He returned about a month later and we carried on with the repair. I will say that I have no clue if this will work on a later AJ27S engine management.
  #32
Old 05-18-2024, 06:47 AM
Is the duel linear switch located in the center console. And testing with test light you mean the J gate plug or.... Thank you
  #33
Old 05-18-2024, 06:51 AM
I have swapped the J gate out of my parts car and still same issue. Also my parts car is a good running car 125,000m it just is rusty in ALL the spots
  #34
Old 05-18-2024, 08:32 AM
Silverjag0's Avatar
I had very same this problem but with one obvious sign when I wanted to start the car the gauges needles where coming down the temperature and fuel it turned to be bad fuse box in the engine bay the small fuse one I would say it is electrical problem
  #35
Old 05-18-2024, 11:58 AM
nilanium's Avatar
OBD codes??
No P light sounds like it could be dlss or microswitch/wiring related, and no-start makes me lean more towards microswitch related possibly?
  #36
Old 05-18-2024, 03:43 PM
The P,N that goes to the dual linear switch comes out of the Body Processor Module. Swap out the BPM and see if that doesn’t take care of it. It’s behind the glovebox. 3 10mm nuts and 1 10mm bolt that holds the large connector to the BPM. Hand tighten the connector bolt and make sure the male and female pins all look good.
  #37
Old 05-19-2024, 07:42 AM
No OBD codes.
  #38
Old 05-19-2024, 09:53 AM
There won’t be any codes in the ECM pertaining to the BPM.
  #39
Old 05-19-2024, 06:35 PM
OK Will do, I will let you know.
  #40
Old 05-26-2024, 07:35 PM
I replaced the BPM still no change.
Quick Reply: 2000 XJR Will start on first try, then no crank w/deathscroll
