2001 Jaguar XJ8 HELP
Do you have the repair history? Have the original tensioners been replaced by the updated 3rd generation tensioners? If not, then I would recommend having yourself or a mechanic pull off the valve covers on both sides of the engine and check to see if the plastic upper secondary tensioners have failed or have cracked (about to fail). Even if they are ok now. If they have not been replaced 3rd generation ones, I would have them replaced now.
Use these 2 websites links to views the information on tensioners problem:
http://www.jagservice.net/jaguar_v8_...tensioners.htm
http://www.jcna.com/library/tech/tech0028.html
Also do a forum search using "tensioners" limit it to the forums of Jaguar sections XJ8 & XJR; XK8 &XKR. That should give enough information on these tensioner problems (posts give others' experiences, DIY, Costs, etc).
Hope this helps.
Hope this helps.
Will P
08-27-2015 06:52 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
