2001 Jaguar xjr coolant leak
Hello, I am new to Jaguar forums. I have read the forums other times to figure out other issues. I have a 2001 Jaguar xjr, currently I have the supercharger off to be rebuilt. Before I took the supercharger off my car has been leaking coolant. Are there any common coolant leak spots that I can check while I have the supercharger off?
Sounds a bit daunting Andy . . .could you possibly explain in more detail . What would have to come off to view these "pipes" ?
It is not a big leak , a drip about every 5 seconds. I can just about see that there is possibly some coolant from around the water pump area, but cannot see an actual Nox Vidmate VLC flow
This is a link to the procedure on a NA X308, but as you have the supercharger off already it should help.
https://www.docdroid.net/yUGg4Gg/jag...s-manifold.pdf
dieselmedia
06-09-2020 12:14 PM
