2001 throttle
Old 06-12-2012 | 07:00 PM
grommet's Avatar
Question 2001 throttle
Hi, does the 2001 3.2 xj8 use an accelerator cable or is it fly by wire?
Old 06-12-2012 | 09:28 PM
test point's Avatar
Don't know that any 3.2L cars made it to the US so you are not going to get many responses from this side of the pond. Since everything else is pretty much the same I would guess that the throttle is also.
Old 06-13-2012 | 03:41 AM
Sean B's Avatar
It uses a throttle cable, but it's used to send the message to the electronic actuator - as in fly by wire as you assume, it's also the same unit fitted to 4.0 and s/c, hope this helps.
grommet (06-13-2012)
sadepol01
08-06-2024 10:10 AM
jimforrest (uk)
02-28-2019 06:42 PM
tomkilner
10-09-2015 07:10 AM
k-man
10-05-2015 08:09 AM
inactualis
10-02-2015 11:13 AM
Quick Reply: 2001 throttle
