2001 VDP Leaking coolant
probably the heater hose connection to the back of the engine block...there is an 'octopus' of hoses behind there with about 5 different points of connection, the plastic fitting (Norma connector) often leaks with age and plastic fatigue. You can buy a whole new hose, or cut off the norma connector, and just clamp that puppy to the metal outlet pipe it was originally snapped onto.
aholbro1
08-05-2021 05:02 AM
OkieTim
09-08-2015 04:48 PM
