2001 VP base cam positon Sensor connector
Got restricted performance and went into limp mode with other alerts out of the blue.
I found the connector from the engine harness to the connector to the cam position sensor on the left side had fallen apart. Can't buy or find just the engine connector so I bought a complete wiring harness for 80 bucks to salvage the connectors.
Also the thottle body assemble needs replacing based on codes that indicate the TPS is shot, so got one on the way that has 1 year warranty for $550 including the shipping.
Plan to replace connectors before throttle body to see what I get before replacing tb.
Anyone have this connector problem before? Jag does not make just the connector or that years wiring harness so we hade to go used.
Any comments would be appreciated.
KarimPA
09-12-2015 08:15 AM
