2001 XJ8 ASC and TRAC not available
#84
Welcome to the forum. Your question is unclear and I almost didn't read it since it's hitched a ride on an old thread. Please open a new thread and provide more details of your problem, then include the year and model of your car.
When you have time, visit the new member area and introduce yourself and your car.
https://www.jaguarforums.com/forum/n...-intro-must-5/
#85
#86
#87
Hey all. quick question. I just had my jag inspected and there were NO fault codes. It passed inspection. However, the ASC and TRAC not available messages come on intermittently along with the ABS light. The weird part is when it comes on:
Sometimes it will flash when I start the car and then immediately go out,
Sometimes it comes on when I'm going 70MPH,
Sometimes it comes on when I'm going 30 MPH,
And sometimes it comes on when I'm parking.
There is no rhyme or reason to it. However, it will go out when I restart the car and may not come on again for days. It's the weirdest thing. I can't pinpoint what the problem is because it doesn't come on at any particular time. We had the front brakes replaced about a month ago. We have not done the rear brakes. Any suggestions about what this could be?
2001 Jaguar XJ8 Vanden Plas
Save yourself a lot of aggravation and just fix the ABS module. I have the same year as you do. This article by Dan Jenson will walk you thru it. I had the same issue constantly for a year and a half. Finally, removed the module and cut a 1 inch square out of the corner with a Dremel tool. (save the cutout piece),pencil soldered the two power supply lines, glued the piece back in, bled the system and "voila" no problems for the last three years.
http://www.jag-lovers.org/snaps/snap_view.php3?id=1230845126[/URL]
Welcome to Jag-lovers - Members Photo Viewing Page
XJDanny (07-28-2018)
#88
I have a 2001 XKR Silverstone with 45k on it. I had very intermittent ABS and TRAC codes appearing on the dash for no rhyme or reason, except maybe high ambient temperature. All sensors check OK, no other issues. So dealer figures out bad ABS module. $2600 module, $500 labor. OKAY -NOT DOING THAT. Found this company in Van Nuys California, Module Repair Pro that rebuilds these modules better than new supposedly (fixes all the bad soldering). $219 plus $100 deposit to return your old one. Ordered that, took it to dealer, they installed and now, no fault codes. Same $500 labor but $219 module cost. Thank you universe!
https://www.shop.modulerepairpro.com
Brad
Brad
#89
I used them, awesome, no complaints. I'll dig for them.. but frankly, it's the solder joints that are loose. There's videos on doing it yourself..basc basic drill a couple small holes per video to allow you to resolder the joints that fail.
https://youtu.be/Rn0_zR258ro
#90
If you got the time, its definitely an ideal way to go!
Brad
#91
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
https://www.ebay.com/itm/REPAIR-kit-1998-99-2000-01-02-03-Jaguar-XJ8-XKR-XK8-ABS-Module-WE-INSTALL/253116887338?hash=item3aeef1312a%3Ag%3AVVMAAOSwmud aBNSX&_sacat=0&_nkw=repair+kit+for+2001+jaguar+abs &_from=R40&rt=nc&_trksid=m570.l1313
Send your unit in, they repair and send back, if you're not comfortable doing the above fix yourself.
Tom
Tom
#92
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/864x865/img_9641_89f6beccb511c77b8c4f065efd89672b932e3c14.jpg)
This crack is very, very tiny. The pin is just a 1/4' tall.
First off, a huge thanks to all the members who shared how to fix the ABS module. This forum is amazing.
Second, a point of clarification. When I cut open the ABS module a month ago, I inspected the suspect pins and they looked fine. My circuit board had a thin layer of colorless sealant over it. This was just opaque enough that I couldn't see the crack at the base.
Third, the pins in the pics ARE VERY TINY. Yesterday, I stripped away the plastic sealant, exposing the pins. With my reading glasses on, the solder looked okay. BUT, when I put on my reading glasses and my wife's reading glasses, a poor man's pair of loups, the crack became visible.
Someone here described himself as having "...mad skills" when it comes to soldering. I have, what I would call, "...bad skills". Despite that, I was able to melt a gob of solder and cover the cracked base. After a year of cleaning wheel sensors and making sure the battery is highly charged, soldering the pins fixed the problem.
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
