2001 xj8 key and fob replacement
I am trying to get a replacement key and fob for my 2001 xj8 and got a couple of replacements but the key portion was too short. does anyone have the part number for the replacements? I was hoping to get the single key and fob instead of the 2 part system. I searched the forums and there were some from ebay but was the 2 part.
Thanks in advance.
Thanks in advance.
The X308 uses a TIBBE key with 8 slot, 3 cuts.
The 'switchblade' keys are 6 slot 4 cut TIBBE.
SONE (forum member) sells keys and will cut them to your locks.
Configuration is on you.
Just send a pic of the key or just tell him the cuts.
Here is a paper TSB I created about 20 years ago from a paper document we got when I worked at the dealer.
If you can get some keys cut, I can configure them to the car. (Bring a 12 pack)
ALL KEYS MUST BE PRESENT AT THE TIME OF CONFIGURATION. Any keys NOT present will be deleted.
I am about 60 miles from Dallas.
Highhorse (03-19-2024)
redeye1962 (06-09-2021)
Howdy, I am in the Garland/Dallas area and wanted to see if you still copied 2005 Jaguar S-type (Tibee) keys. I have three blanks and depending on the price, would probably go with two or maybe three at a time. I have the key with the transponder that starts the car but I need to get at least one spare that will also start the car. You both cut and program keys? If so, if I provided the blanks, what with the charge for two keys be and then what with the charge for three keys be? Thanks!
A member SONE on this forum did cut keys (he cut some for me) but he is in someplace like Nevada or Utah?
He cut them and mailed them to me.
I can CONFIGURE keys but not cut them.
Received 1,795 Likes
Listen to Bob, his Tech experience isn't to be ignored...here is Sone's link
https://www.jaguarforums.com/forum/m...%20Tibbe%20key
motorcarman (03-19-2024)
