2001 xj8 RP on and amber engine light
Hi
I took the car to the dealer and had it scanned codes PO455 and PO333. They replaced canister valve C, car ran fine for 3 days. Then it all started again. RP comes on around 60 miles per hour, goes off when you slow down, but engine light stays on.
Any ideas?
Any ideas?
Changing both knock sensors is easy. It's just undoing the wire harness and removing the sensor. You will need a crow's foot attached to a long extension to loosen and tighten it with a ratchet. You should tighten it to 30 Nm.
Isoruku
06-19-2020 12:54 PM
Robert1968
06-24-2017 11:16 AM
