2001 XJ8 VDP Headlamp/Blinker Fuses
Hey Everybody,
My right blinker and night driving headlamp aren't working, even after I've changed the bulbs. I can't seem to get the daytime driving light out to switch it so I can't say if it would work with a new bulb.
I want to check that the right light fuses are all good. Can anybody direct me where to find the fuses for the Right Headlamps, Blinkers etc?
Many Thanks!
It's a 2001 Jaguar XJ8L Vanden Plas
Many Thanks!
Hi
Look at this other forum thread:
https://www.jaguarforums.com/forum/x...p-issue-60025/
Gives location of relays for highlights. See post # 4 - use weblink to fuse boxes & relays PDF file.
Jim Lombardi
Jim Lombardi
holybananas (10-07-2011)
Still having an issue with the blinker on my XJ8. I couldn't find anywhere in those documents that clearly stated where a fuse or relay would be located in the car. I replaced the headlamp and it's working. The blinker, side marker light are still out. I tried switching the bulbs with brand new ones and it didn't do a thing.
Does anybody know if the Right Blinker/Indicator lights have their own fuse? The rear blinker works just fine!
Hi
Try looking in the Trunk (luggage) Fuse Box
Fuse# 19 (5 AMPS) is for Right-hand side lamps, left-hand and right-hand number plate lights, caravan/trailer.
Fuse# 21 (5 AMPS) is for Left-hand side lamps, left-hand and right-hand sidemarker lights, caravan/trailer.
Also look at Relay #3 in the Trunk (luggage) Fuse Box
Side marker, license plate and trailer rear lamps
Jim Lombardi
Jim Lombardi
aholbro1
08-05-2021 05:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
