2001 XJR Advice
2001 XJR Advice
Hello everyone it's been a while since I last posted. I have just acquired a 2001 XJR with 70k miles and plan to road trip it from New Jersey back to California in about a week's time. It appears it has not had its secondary timing chain tensioners done and will likely still have the "gen 2" tensioners. As of now, it shows no sign or symptoms of bad secondary tensioners, but I obviously realize that the entire timing guide and tensioner system needs to be replaced and I intend to do just that. However, I would like to drive the car from New Jersey (where I bought it) back home to California, and my gut says it'll be fine just cruising on the highway back if it isn't presenting any symptoms of failed tensioners, but I wanted some input from other forum members.
Get the engine serial number and see if you might have a replacement engine in it. My 2001 I bought in NJ did, so logically shouldn't ALL 2001 XJRs bought in NJ? Yes I'm kidding about that, but seriously, unless you know for a fact its the factory engine, its worth getting the serial number to see if you might not have to be concerned.
pagodino
11-24-2015 03:17 PM
