2001 XJR Brake Light Problem
Hello Members:
Getting a Check Brake Light signal on the dash of my 2001 XJR. Both Rear Brake Lights went out at the same time however the Brake Light on the Rear Deck still works. I'm not certain if the switch on the Brake Pedal controls all 3 lights and I don't want to change the switch if it is not necessary. Any help would be appreciated.
The rear brake lights signal run through the security locking module located under the trunk fusebox - it sounds like the surface mounted diodes that control them have burnt out, a fairly common problem. There's a member on here that ID'd them and offered to replace them if you send him the module. Have a search and you'll find the thread.
Hope that helps
Hope that helps
Capitalman1 (06-29-2015)
Brake Lights
Hope that helps
Hope that helps
BrentGardner
28
04-26-2024 03:08 AM
Ziggybeben
08-30-2015 02:09 PM
