2001 XJR calipers
I think the 300s were on X300 models. My front calipers and discs are from an X300 with 305 mm. So it can only be earlier models... Or the 300 mm is for the rear!?
I'll correct you on that one... Brembo-equipped cars like mine actually have 355mm front rotors (13.9".) I seem to remember the rears being 330mm, which is larger than the front rotors on a standard XJR Amusingly enough, Autozone actually carries the 355mm cross-drilled rotors for the Brembo cars.. Not sure if they have the rear rotors or not.
Geezer
10-17-2016 06:19 PM
