2001 xjr p1646
Hi All,
Just got my car back after a long-long time off road and found that it's throwing a code of P1646. The reader is stating that this is a relay on the secondary fuel pump (had both fuel pumps replaced about a year ago). Read somewhere that this may also be the upstream O2 senors? Anyone know which could be the cause?
Andrew
Andrew
all the brown relays in the trunk are the same, you can swap them around
I see the above, but let me tell you about my experience this weekend. I had P1647. Highhorse and my research said left bank O2 sensor. I had a mouse chew off the wires to the knock sensor, so before I ordered a new O2 sensor, I switched the leads to the right and left O2 sensors to make sure not another chewed wire. My P1647 went away and P1646 popped up.
Avro RJ
11-16-2015 08:19 AM
