2001 XJR Parking Brake Warning Light
The rear brakes were recently bled, and since, the parking brake warning light is staying lit, even though the brake handle is in its lowest, released position. I'm assuming that the switch is probably stuck on. where is the switch located, and how easy would it be to replace, if I can't un-stick it? Thanks.
Thanks for all your responses.
I checked the brake fluid reservoir, and it is topped up to max. Ref the table below, the light (Canadian version) AND the warning message are both on, so maybe I have a fault with the brake fluid level sensor and/or the handbrake switch.
Had a look for the handbrake switch, but couldn't see it (difficult to access with being so close to the driver's seat!).
How easy is it to check/replace the brake fluid level sensor?
Thanks in advance.
Thanks in advance.
Wolfy
01-08-2018 05:53 PM
