2001 XJR Power Loss
Does the amber light flash and say trac. Or slip etc...if so its traction control interveening in you throttle application. Turn off traction control and see if it still happens. If its that overlly sensitive you either have incorrect sized tires, old/new etc... There wont be a code for this situation its normal operation as the ecu see's it
Geordie1 (06-05-2012)
