2001 XJR Tranmission Fluid
Guest
Posts: n/a
Our XJR has about 105,000 miles on it. We are not having any problems with the transmission. But I was wondering if it is a good idea to have the fluid changed.
I am also interested in what fluid any one would recommend. I use royal purple fluids in all my other vehicles.
Thanks,
Thanks,
The factory fluid is like $30 or $40 a quart. You need 9 or 10 quarts (from memory). This is not the same transmission as the xj8, and requires different fluid. There is a Shell spec fluid, but I have never seen a price for it. I am about to do the same thing and use Mobil 1 synthetic and see what happens. If anybody else has done this, let me know.
Sorry to edit myself, but MB fluid is available for 15 dollars a quart here:
http://catalog.worldpac.com/ibusines...rt=A%2FT+Fluid
I may use that....and not live dangerously....
Yes, there are alternatives to the factory fluid. We sell it here:
http://www.motorcarsltd.com/_search.php?page=1&q=312
Remember, these is no "fill" hole for these transmissions. It's best to take it to a shop that can pump out the old fluid, change the filter, and pump in fresh stuff. It's not a driveway job.
WHAT????
This is an R he's talking about...the tranny fluid for the Mercedes 722.06 tranny is totally different from that used in a regular XJ8 with the ZF box (and that's a specific Shell fluid also which I wouldn't put anything generic into either.)
Mercedes ATF 236.10 MB part no. is A001 989 2103-10. You MUST NOT USE ANY OTHER FLUID....ATF is often NOT mix compatible although some MB fluids are and some are updates of older types. Put an all purpose synthetic fluid in your 722.6 and good luck to you...get the viscosity/temp range wrong and you'll be typing "722.6" into google frantically.
You can get the Mercedes product on ebay from any number of vendors...I recently paid $75.00 delivered for 6 quarts AND the Filtran OEM filter/pan seal delivered from a vendor that does 722.6 trannies all day everyday, so it's not even expensive if you shop around. (Same tranny used in Dodge Sprinter Trucks BTW!)
WHAT????
Funny thing...I bought it 18k ago, and figured out the sealed trans was low a few months ago. So I added fluid, and the problems went away. I was expecting to find a leak as we discussed, but the trans was dry on the outside. I would bet the leak was fixed, and an incorrect amount of fluid was added before I bought it. When I changed the fluid, I very carefully brought up the level to the correct level with a very hot trans. Now I have it parked on a clean spot in the garage, and we shall see. Maybe I am thinking positively about this, but the shifts seem crisper, all of that. I noticed again that when the level was about half a liter low the trans would not shift into fifth durin my test drives. As I topped it off, it shifted into fifth again. Now I am going to do the same with my other xjr, and then my sl600. I was really impressed with the quality of the seal on the pan. I have done alot of American tranmissions, and thought they could design the pan seal better. Well, this MB pan is done right.
aholbro1
08-05-2021 05:02 AM
chatmanx
09-11-2015 07:17 PM
Wes Steenrod
09-06-2015 06:52 PM
