2001 XJR tranny fluid level
The XJR uses the Mercedes 722.6 transmission and has a dipstick tube but does not have a dipstick. You can buy at ebay or amazon and get some extra break away caps also. Instructions will be included.
Many Chrysler cars and of course Mercedes have the same tranmission, and you could stop at a dealer or transmission shop and ask them to check it.
jandouglass (11-24-2015)
jandouglass (11-25-2015)
What I was trying to explain, although obviously very poorly, is that this is not like a normal dipstick which measures the distance to the fill level from the top of the tube. The stick is pushed down until the top handle end strikes the top of the tube. That means the level measured is dependent on the length of the tube and the length of the dipstick.
The MB (or XJR) design depends on the stick striking something (the bottom of the pan?) at the bottom and measures the distance from the tip of the dipstick to the level, not dependent on the length of the dipstick, as long as it is long enough to bottom out. You could very well use a stiff wire or another long dipstick to do the measurement and google "MB transmission dipstick" to find the measurements vs fill levels.
BTW, my ebay dipstick did not come with instructions.
And... while we are on the subject, although I did check mine vs the IDS measured transmission temperature- as long as you are checking at normal ambient temperatures and you have given a good run up to temperature on the engine, just look at the "cold" vs "hot" measurement marks on the stick and set the level for about 3/4 of the range. You really do not need to worry too much about the absolute temperature unless you are **** retentive. It is, after all, a car transmission and the absolute perfect level just is not all that important.
The following 2 users liked this post by sparkenzap:
jandouglass (11-25-2015),
xjay8 (11-29-2015)
DannyCA
11-23-2015 05:05 AM
