2002 xj8
2002 xj8
Hello all, so I purchased a very clean 2002 xj8 with 80k on the odometer.. the car was garage it's entire life and driven in California & Arizona.. the reason I mentioned this is to just give an idea of how nice this car is.. so the reason I'm here is,it won't run. I read a bunch of post here and I actually was able to get it to start, by addressing a possible cylinder wash situation I read over on a post.
So I what I have is spark at 4 coils that I tested,I did not test all 8
I have 31-35lb of fuel pressure at the testing port.
I have a fully charged battery with very clean cablesMy fuel pump fuse on 7 and I believe 15 is good.
My butterfly port opens as it should on the throttle body
I removed all plugs and cleaned them . I sprayed wd40 in all 8 bores, re installed plugs made sure no wires were pinched when doing so.
The car will start if do an old school pump on the go pedal .. but sputters spits and stalls..
I was able to pull some codes. I need to add them as this tablet I'm on is the obd pad and if I close out post it will be gone. I'll post another. Thank you for reading this post I appreciate any help.. I did read a lot on here so I apologize if this appears as just another xj8 no start post.. I did get as far as I'm at now from this forum.. thanks again
Fuel filter is a good first check so I hope you find the cause soon.
If the pump has been replaced or the fuel tank was pulled into the boot area with the fuel lines left in place, then they could be kinked or damaged and they are NO LONGER AVAILABLE. It is common mistake people make with disastrous results.
thank you randy, i started taking the tank out today, im going to replace the pump.. i put a filter in , no difference. I removed the drive shaft when I towed the car home so that was a bonus on getting to the lines, however I still made a tool.. I'll post pics so the forum can use if they wish.. thanks again for you reply
Sean B (07-24-2023)
after making a tool and having one of the lines come half out and get stuck, I switched gears.. it should not be this hard, I ended up taking the fitting off the inlet side of the filter and left the lines in place on the tank..it gave me plenty of slack.. the tank easily moved out enough to get the pump out.. in the event they break I'd make new lines.. this is my reasoning as I was doing this in 110 degree weather laying under the car with flies trying to survive off the sweat dripping off my face.. yea, not fun lol
Hello Sean, no luck on the pump install even tho I have a significant amount of fuel increase with this bosch pump.. the car starts and runs on maybe 3 or 4 cylinders pops and stalls.. I noticed I have only 6 volts at my injectors.. I guess I'll re check relays which I already have done before I put the pump in.. what's the chances that the immobilizer is shutting it down? Would there be an indicator light I would see? Thanks again for your help
⁹
⁹
motorcarman (07-27-2023)
Jhartz (07-28-2023)
HappyHippie67
02-15-2023 02:38 PM
