2002 XJ8 3.2 Sport Renovation
Old 05-03-2017, 11:27 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
I still think original tips look far too s,all for these cars... Mine are probably far too big but they fill the holes up!
  #82
Old 07-15-2017, 08:07 PM
King Charles's Avatar
Received 1,020 Likes on 741 Posts
Bumping for AC switch info. Thanks !
  #83
Old 07-16-2017, 01:51 AM
Stu 1986's Avatar
Post #34 on Page 2 of this thread, that's where I replaced the switch.
The Part Number is: LJA7658AB
King Charles (07-16-2017)
  #84
Old 07-16-2017, 10:33 PM
All over it, found one on EB for $28 !
  #85
Old 10-26-2017, 03:46 PM
Stu 1986's Avatar
I thought I'd post this in here, seeing that it's part of the car the thread is about.
A couple of months ago I got a code flash up for an upstream 02 sensor fault, which turned on the CEL and put the system onto a default fuelling map. I've not had much cause to use the car so I've kept use to a minimum.
Today I went to my friend's workshop and got the use of a ramp and equipment I don't have. Sean B came over with the 02 Sensor tool and we set to work. As some of you may know the left side upper 02 sensor is the most difficult to do, and this certainly proved to be the case today.
After removing the heat shield and other stuff in the way, we discovered the 02 tool was too long and was causing the breaker bars to foul on the wiper box. I ended up partially dropping the cat down and forward to try and get more leverage on the socket, but it didn't help. Then I did something I've never done in 10 years of X308 ownership, I broke a plastic coolant pipe. Thankfully Sean had a spare set of pipes and was able to repair mine.
In the end I was able to get a 22mm spanner on the sensor and a long length of scaffold pole to get it to break. The rest was easy. Now she's back to 100% and I'm able to use her more.
Whilst I had the workshop I did some under sealing, and I cleaned my wheels on the insides too.
No pictures I'm afraid I was too involved in the job.
Special Thanks to Sean B for all his help today.
The following 3 users liked this post by Stu 1986:
A.J.P (10-29-2017), Don B (10-26-2017), Sean B (10-27-2017)
  #86
Old 10-27-2017, 07:29 PM
Sean B's Avatar
Received 1,357 Likes on 1,068 Posts
My pleasure Stu, got my mind off other things for a couple of hours find it hard to believe that's the first thing you've bust on your Jag's, I distinctly recall an episode with JCB digger and a bonnet
Lovely car by the way.
A.J.P (10-29-2017)
  #87
Old 10-28-2017, 03:49 AM
Stu 1986's Avatar
I’ve destroyed, broken and disfigured plenty of Jag parts but never one of the plastic coolant pipes. They are perhaps the easiest and most frequently broken things when working on the engine, but I’d never done it! Until then. Gives me more cause to look into alternatives.
The bonnet incident was when I reversed the MG ZT onto Felix 1’s bonnet that was lying on the grass. LOL The JCB was when I dropped the AJ27 into the car by accident narrowly missing your hands.
But it’s all par for the course, learn from your mistakes as they say. Nowadays I’m a much more disciplined mechanic than back then, or I’d like to think I am.
A.J.P (10-29-2017)
  #88
Old 10-30-2017, 11:40 AM
Rpach10115's Avatar
Yeah, these are a little big....
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
