2002 xj8 4.0l se
The speaker for the turn signals/key in ignition/door open etc, is behind the perforated section on the right-hand side of the steering column, directly forward of the ignition switch.
The speaker is approx 2 1/2" in diameter and is easily accessed, all you need to do is remove the two screws from under the steering column and drop the cowl down, and the speaker is exposed.
Not sure that is the cause of your problem, but that is how you access the speaker.
