2002 XJ8 Driver's side window control
When my drivers window would not work as well as the sunroof I did a hard rest with the battery cables. It restored my window function as well as my sunroof. Remove negative cable from battery and touch it to the connected positive post and hold for 10 to 20 seconds. It happened after I had unlocked the driver door with the key, not the remote.
motorcarman (05-25-2019)
grantorino2 beat me to it!!
I just did this for my 1999 XJ8L that had the same fault except that I did not want my trip mileage to go to zero so I removed the fuse in the left hand heelboard box for the Drver's Door Module.
Every few years this happens and I don't know the reason. I just pull the fuse, put it back and go on with my life.
bob
bob
The following 2 users liked this post by motorcarman:
dinty (09-03-2019),
grantorino62 (05-26-2019)
wrd0225
is it fixed?
I have EXACT same problem. 2002 XJ8
Pulling 25A fuse at slot 15 in panel fuse box isno joy. does not fix.
Have not tried battery reset.
I am also looking for a relay that controls each window motor. I do not believe that the window motor would be controlled directly from the door switch?
Tom
xj8xj6
is it fixed?
Tom
xj8xj6
texevora
12-26-2018 11:01 AM
Johnken
04-14-2016 12:34 PM
AlbBolivar
07-09-2014 04:00 PM
