2002 XJ8 Idler and tensioner pulley
I am getting a clicking sound when I do a cold start in the mornings and the temp is less than 60 degrees F. I opened the hood and it is the tensioner pulley making the noise. It seems to be catching and then snapping back to make the noise. The noise stops in about a minute and all is smooth. I am going to replace the idler and tensioner pullies unless someone has seen this before.
I have been searching the forum but could not find the torque spec. for the pulley bolts. Anyone?
Thank you for the help.
hunterpayne (09-26-2012)
tensioner pully bolt
I realize thjis is an older thread but can anyone tell me if the bolt to this tensioner pulley is a reverse thread and where might I find a source for a new one. The bolt on my 2001 XJ8 tensioner pulley is rounded and makes it extremely difficult to remove and replace the belt. I just replaced the thermostat housing, water outlet pipe and the water pump all for about $130 (and some skinned knuckles) thanks to all of the great information on this forum.
The bolt holding the tensioner to the block is not; the bolt releasing spring tension is a reverse thread. Most good hardware or auto parts store should be able to replace the one to the block. The one for releasing tension comes with a new bolt with a new tensioner (I broke my tensioner bolt).
How sure are you that the noise is from the tensioner and not the port side VVT? Or a loose secondary timing chain?
The following 2 users liked this post by Jhartz:
badger2196 (12-08-2014),
Whitey (12-30-2013)
mls0036
10-17-2015 10:03 AM
Dickie_L_J_O
09-13-2015 07:44 AM
