2002 xj8 water pump
Hello,
Need some help on installing a new water pump.The new WPcomes with a gasket and o-ring, but I am trying to determine where the o-ring actually goes. The old WP had the o-ring around the lip, but it has a groove for it. Does the new o-ring go at the end of the lip instead around the lip like the original?
Thanks for the help
Thanks for the help
I am literally sitting here with a new AJ8 8912 pump in my hand, there is a flat steel gasket for the mounting face and no rubber O ring of any sort used for its sealing or installation. The aluminum gasket with bonded O ring is obsolete. What you have in your hands is what you got, and if it differs from mine it is not the latest style Jaguar factory water pump.
Dan R (02-01-2011)
Dicque
09-19-2015 12:53 PM
