2002 XJ8 Wont Start
Hi again
The battery is almost recovered so I thought I'd check the spark plugs for condition before trying again. However, on removing the coil packs, one was covered in oil, the rubber sleeving and the bottom of the port is sodden. Could this have been the problem or could it be a result of the cranking?
I'm hoping that the seal around the plug has blown and replacing all plugs combined with a healthy battery will solve my problems. Could it be anything more problematic and could I do any more damage by continuing on my present path?
Thanks again
Thanks again
Hi again,
Romoved plugs, few drops of oil into each cylinder, new plugs in, turned her over a few times, re-connected coils and she started up first time! However.. after leaving it idle on the drive for about 10 mins I thought I'd blip the throttle slightly, it stalled and didn't want to wake up again.
Any ideas guys, you've been brilliant so far and it's really appreciated?
Hi again,
Jim
#31
#32
Followed the same steps, plugs out, oil in etc etc (but with a new battery)... started first time. I feathered the throttle after about 10 mins of idling and reluctantly the revs started to increase. Moved back and forth on my 15m drive before braving to switch of and re-start. Fired up without a complaint!! The Cat purred on a 10 mile spin, and hasn't missed a beat. Thank you all very much, your advice has been much appreciated and has saved me £100's.
I've always wanted an XJ, for me it is the ultimate saloon car, thankfully people like yourselves mean that not all problems have to be fixed/diagnosed by main dealers which would make ownership unviable.
I doubt if my tech know-how will ever be of assistance to anyone but if someone needs another pair of hands in the south wales uk area let me know.
Thanks Again
Thanks Again
#33
Also, if anyone is looking for a replacement battery check these guys out on ebay, "jag-land-uk", I had exactly the same battery (new) that the main dealers were offering and next day delivery for £55 inclusive. Should've been delivery within 3-4 days, told them I was desperate and I recieved it next day at no extra cost. Bargain
#35
I have had my XJ8 for 11 years. About two years ago, I began having problems starting. I also saw some other REALLY ODD behaviours. Use the front driver's side window switch and the rear windows go down, etc. I found that there was something draining the battery, but even the dealer (who kept the car for 2-weeks while he let us drive a loaner jag) couldn't find the problem. He changed out the battery (no -charge for anything) and it worked fine... for a while. However, I haven't had any problems starting lately, even after parking the car at the airport for more than a week while I was traveling. I have found that the weird behaviors go away, if I disconnect the battery to reset the main computer. Another poster recommended touching the negative terminal connector to the positve connector to ensure that any capacitive energy stored in the computer is released. I'm not sure if this matters, but reseting the computer -- with a FULLY CHARGED -- battery seems to solve most ills. It is possible that after doing this, that the idle setting is confused which may make it difficult to start initially, but not the second time. This "fix" has solved transmission hard downshifting problems as well -- the computer controls everything in this car. My recomendation -- First make sure the battery is FULLY CHARGED -- then do a hard reset of the computer by removing the negative battery connector and holding it to the positive terminal (which is still connected). This removes all potential energy differences. Then reconnect the negative connector and try again. This is an easy do-it-yourself first try. Whether it works or not, it didn't cost you anything. Many times it has worked for me.
