2002 XJR 100 - extended cranking when warm - help please!
Old 02-20-2011 | 11:52 PM
PaleRider's Avatar
Originally Posted by Gus
Smithy,
I posted this on you intro post and not sure you saw my post. Turn the key on count to ten then start the car and see if it starts quicker.
After reading this I told my daughter (now her car) to try it before starting. Was really wishing it would help but it does not seem to make a difference.
Last time we changed to a new battery it still did not make a difference in the conditions.
Old 02-25-2011 | 01:53 PM
smithy's Avatar
Default update No 2
fuel dampers changed and ...... no difference!! aarrgghhh
Crank sensor changed and........ no difference !!
This problem has gone to the top at Jaguar UK Tech support and is proving a tough one!
not sure where to go from here apart from some major ££
Tank out and new fuel pumps is an option but we (The "we" is Tom at TL Jaguar ) is not conviced though
All comments and thoughts appreicated
Old 02-25-2011 | 04:05 PM
Gus's Avatar
Gus
I would think if you put a fuel pressure gauge on the schrader valve you could see if the fuel pressure drops off quickly and if it returns when the key is turned on.
Old 01-01-2012 | 07:55 AM
Sean B's Avatar
Hello and welcome. It'd be a good thing to introduce yourself in the new members forum, and maybe start a thread on which car you seek.
My guess would be try pistonheads, autotrader, ebay etc. But, you'll be lucky. The 100's seem to have found enthusiast owners, and only 80 odd made makes it a mission. Took me 12 months to find one. Good luck!
Forcedair1
05-14-2023 04:28 PM
dsnyder586
04-04-2019 03:38 PM
Dicque
09-19-2015 01:53 PM
convincor
09-10-2015 07:50 AM
Doovoe
XJ40 ( XJ81 )
09-06-2015 11:54 AM
Quick Reply: 2002 XJR 100 - extended cranking when warm - help please!
