2002 XJR 100 Question
I am getting ready to purchase a 2002 XJR 100. From everything I've seen and read about these cars, it should say "Jaguar XJR 100" on the passenger dashboard. The majority of these cars I have looked at have standard brown wood on the interior with this across the passenger dash. I have seen a select few with a different color wood interior (more gray), including the one I am purchasing, but it does not have this insignia across the dash. Everything else is the same as the others such as the red stitching, all other badges, wheels, brakes, etc. Does anyone know if two different wood colors were used in these cars and why certain ones do not have the XJR 100 across the passenger dash. I have verified with Jaguar it is an authentic XJR 100 but no one thus far can answer this question. Any response would help. Thanks
I hope I can help - I have a 100 and the decal on the passenger airbag is there. The standard wood for these cars is the grey stained birdseye maple. Now upon ordering from Jaguar, you could specify what colour wood you wanted, my guess is the original owner ordered a different woodset, and of course the decal wouldn't be there as Jaguar only prepared and supplied the grey woodset (from the special vehicle dept or SVO) with the said decal.
As a side note, I've bought a complete spare set and had it painted body colour, and fitted a decal in the same place. I can send you a decal, you will have to remove the airbag panel and take it to a paint shop to have it put on and a coat of clear sprayed over the top, easy and cheap.
Does it have the "100" kick plates on the door sills?
It does have the 100 on the door sills, and I have verified it is authentic, it just bothered me the XJR 100 wasnt on the passenger dash. I want to keep it as original as possible and the dealership is going to get in contact with the original owner to see if any changes were made when she owned the vehicle. Thanks for your help.
All the 100's I have come across have the dark birds-eye maple. I almost bought one when my VDP was totaled but the car was too much of a premium over the base XJR for what was included. They did not sell all that well as many did not like the dark wood or want the problems with the brakes and wheels .. plus the price. It is possible that Jaguar made an arrangement to switch out the wood in order to sell one.
Maybe the wood on this cars dash was replaced and the replacement did not have the decal although the normal factory fix was to send them to CA for refinishing ...... maybe the decals are on top of the finish and are lost when this takes place. I know a lot of the dark wood had to go to be refinished -- for some reason -- maybe heat -- it discolored. That could also be a reason why some of the 100's you came across now have walnut.
I have emailed Jaguar to get the original factory specs, I'll have to compare it to specs sheets I have for other XJR 100's to see if a different wood was ordered. If this car came from the factory this way and has not been altered, my thought is that this would make the car even more rare. I have read they sold 240 in North America with left hand drive, can anyone verify this?
Features
Equipment:Automatic TransmissionSpecial Edition BadgesBonnet LeaperGarage Door OpenerAuto Dim Interior MirrorAudio & CassetteHeated Front SeatsUnique SeatPremium SoundSport SeatsX-Drilled Brembo BrakesReverse Park ControlSilver Wheels & BrakesSuper Sport SuspensionAlloy Space Saver Wheel19x8.5 Montreal wheelsAdaptive Damping (CATS)Rain Sensing WipersBlack Fascia and Upper Door TrimSecurity SystemUnique TreadplatesSunroofNo Lines or MouldingsSVO Strg Whl & R PackWire Mesh GrilleCD 6 disc MultichangerNavigation + Disc 2 USACupholders (Front)CRUISE CONTROL Non ACCMemory FunctionDrvr=12 way Pass=12 way Rec.Heated Rear Bench SeatCarpet MatsRear Cigarette Lighter2002 Model Year
Trim Details
Trim:Charcoal XJR100Paint:Anthracite
Trim Items:Sport TrimWarm Charcoal/Warm Charcoal FaciaNimbus Grey HeadliningFlint Grey CarpetCharcoalCharcoal/Charcoal ConsoleTwin Needle StitchingCharcoal Seat BeltsCherry Red StitchingNimbus UpperUnique Veneer (100)Charcoal Welts
I know of this car the original owner is a member of the local Jaguar club.
Trim Details
Thanks so much for the info. If you are familiar with this car and the previous owner, I would love to find out if they ordered it from the factory to their specifications or bought it as is off the lot. Any info on why the XJR 100 is not on the passenger dash and whether or not it ever was would really help. If you have contact with the previous owner I would love to speak with them if possible. Thanks again for the info.
Yeldogt is referring to cost of brake disc/pad and curbed wheel trims.
"Any info on why the XJR 100 is not on the passenger dash and whether or not it ever was would really help." Jaxkr's confirmed it came with the car supplied,
"UpperUnique Veneer (100)"
I've seen differences in nearly every one I've looked at. Some with sun roofs, some without the kick panels, some with headlamp wash and that's just the UK cars of 85 odd. At 8-9 years old all have history. I wouldn't be too fussed, I'm sure Jaguar have one, it'll be pricey though.
Look at this car at the bottom of the page, asking £50/$77k it does look mint.
http://www.zwakmanjaguar.com/html/pictures.php
I think they're a future classic.
@ John - 19" rings aren't being made - the guy who makes the 18/20 rings isn't planning on doing any either he's in the UK. The only option is to strip damaged rings and mirror polish the alloy rim behind. Or buy a new rim...
All 100's came with Nimbus grey headliner not black suede, that's an XFR item in black Alcantara, I've fitted storm grey Alcantara to my 100S.
The orange signals can be converted into indicators or badges fitted - up to you.
Well, actually I live in Florida now and the car I bought I bought in Ft Lauderdale. It appeared the car had spent most of its life in the Miami area. I noticed yesterday the sales brochures for these cars show the yellow reflector on the front fender. I was told the models that stayed in europe had the reflectors that were actually turn signals and the cars shipped to the us had the emblem.
No, all 100 were fitted with nimbus headliner it's not black. If you have pictures to prove otherwise I'd be most interested. Of course the headliner does fail on these, so a replacement in a different colour is a possibility.
