2002 XJR Driver's door actuator
My driver's side door wouldn't open/unlock from the inside or outside. I ended buying a used latch assembly and replacing it myself. Now, the door still won't open using the inside door handle AND, when I pull on the driver's side door handle, it locks all of the other doors, but still doesn't open the driver's door.
Any suggestions on how to fix this issue?
Vector
I checked the actuating cable (from the door handle to the latch) and it appears to still be in tact as the end is still on. When I pull on the handle, I can hear the latch pulling, but it the door still won't open. When I would pull on it before, the doors would actually unlock. Now, the other doors lock when I try to open the driver's door from inside
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
