2002 xjr fuel pump problem?
Hello I'm trying to get my 2002 xjr back on the road. It's been setting for a few years now I put a new/used maf and have new bosch 02 sensors I need to install. Currently its outside on gravel drive, it ran a while ago but rough. Now it won't start, no fuel to fuel rail.
I removed the line going to the fuel filter under the car, a little gas came out but when turning over engine nothing. I removed the fuses #7 and #18 jumped to battery on both sides and both fuse nothing out of the filter. Only on the #7 did I get a small spart when touching to + side of battery nothing anywhere else. But can't hear the pump working and there isn't gas out of the filter.
Do I need to replace the pumps? I've done this twice before on other xjr's really not looking forward to this. Are there anyother steps I should check before I pull the trunk?
By the way I poured some gas down the intake throttle body and it ran rough for a few seconds.
A few years back I bought my 2002 XJR from an owner in Orlando (sight unseen). He put it on a transporter to Dallas. I unloaded it and ran it around the block. Everything worked fine...no warning lights or codes. Then had to put it away for a few months. When I went to restart it, both pumps were stone cold dead. I went in through the back seat parcel shelf for the replacement.
I think the effort is about equal. Only real advantage is if I have to do the job again...cut the tack welds on the "lid", and there it is. I used a Dremel with a box of cutoff wheels and a canvas "blanket" stuffed up over the tank top to protect from sparks. Also very difficult to see inside the tank because of rear window angle...mirrors and feel. It was 100 degrees F when I did it, so that added to the pain.... Here's a link to photos...
https://www.jaguarforums.com/forum/x...l-pump-242935/
Also look at this current, related thread Helpful Hints wanted - Jaguar Forums - Jaguar Enthusiasts Forum
your right about pump #2 is fuse 15, diagram on line wasn't too clear and looked like an 18 (both are 20 amp fuses) anyway found my book on the car and verified the fuse, tested and either pump arn't working...
checked out the panel on behind the rear seat and unable to access the pump there.
watched a video where tank was pulled out a little ways without disconnecting the fuel lines, gonna try that when rain stops (car is outside on gravel drive way.)
just looked at the pictures of cutting a access panel on the deck behind the rear seat... i may try that (not the first time I've done something like this on my 94 camaro convertible it has similar problem, need to drop the tank to change the fuel pump. I cut hole in deck behind the rear seat and got it out. anyway thanks for all the info and now I have options on how to proceed;
FYI, the rear seat bottom and back, seat belts/inertia reels, speaker, head rests, and the finish tray(s) on the shelf need to come out. That alone is a pretty time-consuming task. Helps if you have a second set of hands when extracting the big chunks out the doors. It goes back together much quicker than removal....
The electrical plug at the top can be removed from inside the trunk (pull the trim panel out) to preclude cutting the wires when you slice into the metal. The Autozone Delphi pumps fit the rubber isolation brackets with very minor Exacto Knife trimming. Also, the pump plugs match the ones in the Jaguar harness. Finally, the original Jaguar suction filter pads are part of the failure scenario in my estimation....
If you have the plastic hose removal tool and have thin forearms, or can persuade someone who has to push them up into the tank base, you've won the job right there, auto shutoff, pulled clear and the tank ready to be cleared...
Loosen the 2 steel bands pinning the tank and hook them to the trunk lid (propped)
Undo the filler neck and overfill pipe...
Hard board onto the spare wheel, and slide the tank forward from the top.
I did this job last summer, it's simple if you have the tools and thin arms, it's tight.
The car ran well, but I felt it was a little down on power. Then it wouldn't start. It was operating on one fuel pump for I don't know how long, they don't go out together, one can fail, but there's the second, once that goes kaput then...OE connector on the pumps, then it's a case of doing the job once.
americanwoman63
08-22-2017 10:59 PM
juwels365
08-05-2014 12:55 PM
