2002 XJR tires
Guest
Posts: n/a
2002 XJR tires
I need tires and I would like to get some Nankang tires. Heard good things, and like the looks and price. My car lists the factory size required as 255/40/18. Can I use a different size? I am not looking for a custom look...I just want a close to factory look for my tires
[IMG]local://upfiles/5330/EE2F4E351C624061B8A1FACF84799807.jpg[/IMG]
Guest
Posts: n/a
RE: 2002 XJR tires
The first two numbers are width and profile, so 255/40/18 is (255 wide/40% as tall/18 inch rim). You can play with the width and aspect/profile ratioa little, as long as you make sure the tire circumference stays the same as the factory specs (so your speedometer isn't off) and the width doesn't scrub the inner fender, etc. If you can't get specs for the circumference, make sure to check the total diameter or total tire height, usually if it iswithin a quarter of an inch or so you'll be fine (ride height, speedo accuracy, etc).
Dicque
09-19-2015 12:53 PM
