2002 XJR100 Sitting for 3 years
Since you already have the pumps out you might as well replace them and go forward . They don't last forever and there not that expensive . Do replace the relays and you will have the things that are electromechanicaly dependent on each other covered . After you have done that we will go through the control circuit of the relays that contacts the power circuit to drive the pumps . I have experience on both control and power circuits of this system . On the print I made above you will see the position of the # 2 pump relay
Any questions , just ask
Received 1,803 Likes
Here's a couple things to put in your Jag ammunition bag....
Save this one to your favorites, JagRepair.com - Jaguar Repair Information Resource ...I already have it at the electrical guide, prompt the first result.
Here, link 2 tells where to get the Workshop Manual.... https://www.jaguarforums.com/forum/x...al-pdf-183893/
The PDF below may help also...
1 of 19 (01-15-2018)
By the way, just remembered - I had a no start on my 100 that turned out to be a bad connection on the engine temp sensor, cleaned up the connections, (flooded with wd40 and a few off/on connections) it fired first time - this after sitting all winter last year - another item to check, as this inhibits engine start if coolant temp signal is lost.
Alright guys soooo, got my airtex pumps and I installed them, in the time ive been waiting for my pumps the car actually stopped cranking. the battery is fine, when i try to start it all i hear is a loud click. I have a feeling i burned out the starter while cranking it over and over last week while the pumps were dead.
#28
Swap out the starter relay and a good battery charge of 12.77 volts , you are getting the commanded signal for it to engage , just wont motate . Starter motors do have a duty cycle that nobody thinks about in the heat of battle . There is a starter rebuild kit on Ebay from England if it comes to that . I Never used one .
You can have the battery load tested for free at the auto part store
#30
I have brought a dozen or so 308s back from the dead and what you are describing is usually one of two things, the key or the battery, but usually the key. I did have one with a battery so fried that even on my huge 200a box she wouldn't crank.
#32
#33
Alright guys,
1. How could it be the key if just a few days ago it was cranking just fine? nothing has changed since then.
To describe it is i turn the key to crank and its just one loud CLICK sound and thats it
2. as for it being the battery it is holding just fine at 12. And I put jumper cables on it from a running car and tried to crank it that way too and same exact click sound. so I would rule out the battery at that point.
I have had many bmws and mercedes and cant remember a single time that a relay has gone out, is it actually that common in JAG for a relay to be the cause of something? i have 1 brand new relay for it and i think all the relays are the same so ill test that.
#34
The loud click ( of the starter and the relay both ) verifies you have a correct commanded signal by way of the key switch . Now it is the amount of power we are concerned with by insuring you have a good power contact inside the relay by swapping and ensuring a fully charged battery . The last thing would be to remove the starter . Someone once had a loose starter terminal post on the engine firewall and was easy to tighten up and is your engine ground strap clean and secure ?
Someone mentioned Jaguar's don't take too well with jump starting and this I don't understand . Can someone explain ?
Not to get picky with how accurate the battery voltage reading is but a 12.0 reading is a 50 % charge .
#35
Jump starts are bad for the car if you leave the ignition on and hook up, I left my car in the paintshop and it required a jump start to move it multiple fuses blown on the left and right heel boards - steering column control, front seats etc, lots of stuff dead. I kind of held my temper with the guy who did it...
+1 on 12V it needs to be a battery in good order or new to run the systems on these cars - it needs over 12.5V minimum, even then you'll get TRAC/STAB/ABS warnings flashing on cranking. The click is the starter relay on the front left hand inner wing panel bracket, either you've a dying battery and it's trying to start, a bad earth. No to burnt out starter, no to bad relay. Plain and simple from me at this point
The following 2 users liked this post by Sean B:
Craig Mason (09-20-2019),
Lady Penelope (01-11-2018)
#36
#37
No pics but this may help :
https://www.jaguarforums.com/forum/x...r-motor-76686/
and
https://www.jaguarforums.com/forum/x...ast-way-77394/
and
#38
Alright guys here we go, CHecked fuel pressure at the rain and now i have it since i replaced the pumps, I found the starter and knocked on it while cranking and it cranked now but the battery was super weak, but at least now i know it was the starter causing that click, soooooooo i need a starter and a battery. I am about to order a desno starter, What battery do i get and from where please. i believe we are getting close i can feel it.
